Question about GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
My GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
  • GE Master
  • 4,656 Answers
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
SOURCE:
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 12, 2010 | GE Refrigerators
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Logo
1,724 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
geapptech
Audie Bogus
Audie Bogus
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
