NOT pfaff hobby 426o but hobby 309
feed feet up and moving but fabric just sits there. stitches look fine if I pull fabric through manually (unevenly of course)
I've adjusted the lever below for feed feet up and down and it seems to work fine and the feet come back to the up position.
threaded all ok, presser foot lowered, of course
everything seems fine - what else is there to check?
just bought this machine at a yard sale, but have used pfaff's before at work and used to have one of my own
When I first got my creative 1473 it was pretty much the same story... after gentle repeated tries over the next few days the presser bar came down all the way. It simply hadn't been touched in 20 years and needed some 'warming up', so to speak.
Either the presser foot does not have enough pressure on it or it is not lowering all the way to the fabric.
Remove the fabric.lower the presser foot.If the presser foot has no or little pressure look for the pressure regulator on top the machine or on the left side and see if you can make it tighter. Not all machines have this.Look to see if there is space between the foot and the teeth when you turn the handwheel. If there is space then the machine needs an adjustment.
sewman7
Thanks for your assistance, both. I took the machine in for repair and it's all fixed now. It was some internal thing that couldn't be adjusted without taking it all apart. It needed cleaning and tune up anyway, so all was OK.
