Archos Internet Media Tablet MP3 Player Logo
Posted on Apr 27, 2009
ARCHOS 5 - Video will not load (frozen)
I am hoping someone can help. I have the Archos 5 and the video will not load. Everything else on the system works except video. When I click on the video icon to watch a movie it won't even open up the list of movies I have on there. The hour glass comes up and it just sits there.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
5171
Points
12
please check the file format and try again. you can read the user guide for more info..
trevor
1helpful
Archos 5 internet tablet won't play youtube video from youtube them selves or via mobile youtube
Hello wilko1974, This has been an on going issue for Archos 5 users. The new youtube supports flash 10.1+ and the Archos 5 only supports 9. Unfortunately there does not seem to be a clear cut solution for this issue. Archos has not released a firmware update for this and with their new devices it there support for older devices has lowered. I have found that choosing the lower play button that appears over a video plays on Archos more often than the top button. I would recommend trying this and seeing if you get better results. Another possible solution is to open the video in a new window with the link on the top right of youtube video. This however is not on all youtube video pages and with the currently layout is on accessible when the video submitter enables it. It also help to have the latest firmware updates that can be done directly on your device. Hope this helps, Greg
2answers
As a new mac user, how do I get dvd's and music onto my archos 605?
Try to reset the MP3 by holding the power button down for 15 seconds and it will turn off and reset;
Hope it may help you;
Regards,
VOTIT
tip
Watch various videos and unprotected DVDs on ARCHOS 7
The ARCHOS 7 offers customer uncompromised access to the Internet, TV and media content… With its stunning 7 inches amazingly high-resolution screen, 800x480 pixels, and huge disk capacity, it is the best travel company and portable audio/video player you can imagine, which will definitely accompany your travels and holidays in a comfortable and convenient way.
To enjoy videos on ARCHOS 7, you should make sure what file formats are compatible with it, following is the detailed information:
Video playback:
MPEG-4 (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution) including WMV protected files
M-JPEG (Motion JPEG Video) in QVGA resolution
With optional plug-in (downloadable from your tablet on www.ARCHOS.com):
HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
H.264 up to DVD resolution with AAC
MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
Audio playback:
Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WMA pro 5.1, WAV (PCM/ADPCM)
AC3 stereo audio and 5.1 sound files (via SPDIF output of DVR Station)
Flac and OGG Vorbis audio files
With optional software plug-ins (downloadable from your tablet on www.ARCHOS.com):
AAC, AAC+ stereo audio files
Obviously, the ARCHOS 7 supported file formats are limited, if you want to watch you various video files and unprotected DVDs on it successfully, format conversion is necessary. By now, Pavtube Video Converter would be a good assistant for you. It is able to help you convert videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), YouTube (*.flv, *.f4v), *.mts, *.m2ts, *.mkv, etc. to ARCHOS 7 compatible format. You can look through its step by step guide as below.
Step 1: Run Pavtube Video Converter, and click "Add" button to load video files to it
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format" firstly, and then select "Archos", after that, all the profiles for Archos will be listed out, here I choose "Archos 5/7 WMV Video (*.wmv) for example.
Step 3: Specify destination folder
Click on the folder icon at the end of "Output" to specify where to locate the output files.
Step 4: Click on "Settings" button to adjust audio and video parameters
Actually, the default settings can basically satisfy your ARCHOS 7, but if you want to have your own changes, you can adjust all the items like codec, aspect ratio, frame rate, sample rate, bit rate, and audio channel in the following window:
Step 5: Click "Convert" button to start conversion
Once conversion is finished, the output files can be found out via clicking on "Open" button with ease. Afterwards, just enjoy them on your ARCHOS 7 freely.
For more: http://www.pavtube.com/video_converter/
on Feb 23, 2010 • Televison & Video
10helpful
3answers
Recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
15helpful
6answers
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
My archos 404 says to play video with mpeg1/mp2 i need to purchase a software plugin which is available at www.archos.com
Just convert the movie to MPEG4 ASP (Level 5), XviD, DivX 4, DivX 5 or WMV9 (max resolution of 704x 480 @ 30fps, 720 X 576 @ 25fps) format on your desktop computer an then load it onto Archos
5helpful
4answers
Archos 605 WiFi "Cannot play video! Please Check"...
This problem seems to occur when the device overheats. It doesn't make a whole lot of sense, but all my videos set at 720 by 480 wont play when the device is left running for a long period of time. The smaller video files, however, still play. I think it deals with the amount of system resources required for such files to play. If you turn the device off completely by going to menu, power, and turn off device, and leave it sit for 30 minutes, all files should play properly when you turn it back on.
As a suggestion, DO NOT leave your Archos powered on and on the dvr station. This causes the device to constantly run, and if you havent noticed the Archos operates at an extremely high temperature.
2answers
Help me pleaseeee
sent it back to archos with your receipt if less than 1 year and talk to customer service
there is nothingg you can do about it
been there done that.
Archos AV504 problem
you cannot change any thing on the AV,500GH the mechanism are built in to work on operating system 1.5.12.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
