The freezer is fine, but water is dripping down from back of refrigerator and settling in the veg & fruit bins and also on bottom of refrigerator. It does not run out the bottom to the floor only inside the refrigerator.
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water is dripping from air vent (topside) to vegetable basket. pl give solution to solve this one.
The water from the freezer is dripping down the back of the refrigerator into the vegetable bins and into the bottom of the refrigerator. The tray under the referigerator is dry.
Model # ET21PKXGX03. The drain plug is located in the rear of the freezer and there is no access to it. The rear panel is sealed. There is no cup as you suggested. This happened once before and I used a wire and ran it up the drain tube to the plug. This time ...no luck. Any suggestions?
