Question about Kingston Datatraveler Vault Privacy Edition Usb Flash Drive 4 Gb Usb
Unable to locate the removable drive - Kingston Datatraveler Vault Privacy Edition Usb Flash Drive 4 Gb Usb
  • abdellah mazoz
    abdellah mazoz Jul 19, 2018
    it works with other windows machines but not mine. (The error is appearing after turning it into boot linux, what to do for). Thank you
    Sergeant:
    Habit-Forming:
  • Kingston Expert
  • 91 Answers
If the drive does work on other computers - or you don't have another computer around to test this with - Windows may be having a driver problem with thedrive. You can check for this using the Device Manager. To open it, press Windows Key + R, type "devmgmt.msc" into the Run dialog, and press Enter.Watch online club Watch online free Bollywood Hindi Movies HD Quality Watch online club Watch online free Bollywood Hindi Movies HD Quality
Posted on Jul 19, 2018
  • abdellah mazoz
    Thanks for your anser. the drive is working on other computers.
  • abdellah mazoz
    Top Expert:
  • Kingston Master
  • 29,411 Answers
Perhaps it has been removed ...
  • abdellah mazoz
  • JonSnell Electronic
    JonSnell Electronic Jul 19, 2018
    Windows likes Fat32 for USB drives and has trouble with Linux and Mac.
SOURCE:
How can I import songs on PC to Trio Rythm Touch2.8v
Transferring songs to your Trio MP3 Player
This is the Copy and Paste Method
A. Connect your MP3 player to a working USB port
When the unit is connected to your computer, it will create a gray and green icon in the system tray (lower right hand corner of your
desktop).
The icon will be called safely remove hardware.
B.Go to the "My Computer" section of your computer. In there you will find a section called "devices with removable storage"
Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending
on your system configuration.
C.Open the drive by either double left clicking on the drive itself, or by right clicking, or left clicking on the "Open" option on
the menu.
D.Locate the music stored on your computer. Generally this is stored in the "My Music" folder of your computer.
NOTE: if you are unable to locate the music on your computer, click on start, search, files and folders, then search for .MP3, or.WMA
E.Once you have located the song files, you can right click on the song itself, and select "copy".
F.Open the removable disk drive, right click on in the empty space, and select Paste.
This will transfer the song on to your MP3 player
Please take time to rate me
Bud
Oct 26, 2012 | Audio Players & Recorders
Red light on on my Buffalo HD
Red ERROR LED The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error E 01 DRAM data line error E 02 DRAM address line error E 03 RTC chip error E 04 Flash rom error E 10 UPS power loss E 11 fan error (RPM too low or not functional) E 12 cooling error (unable to remove heat by the fan) E 15 disk error E 16 unable to locate internal HDD E 17 Unable to communicate with the RTC chip E 21 unable to communicate with the Phy chip E 22 mount error. The original Buffalo firmware has the following error messages based on the number of flashes:
3 Partition problem with hard drive. Reformat the hard drive. 4 Fan problem. 5 ROM problem. 6 Hard Drive can not be recognized. 7 Problem with motherboard (RAM, LAN, or Hard Drive controller). Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
Jul 20, 2011 | Buffalo Technology (USA), INC. - 500GB...
I PUT A CD IN CLOSED THE TRAY...THEN WHEN I RE OPENED THE DRAW OPENED BUT WITHOUT THE CD
The CD may have been inserted loosely in the tray and shifted inside the notebook during transit or use.
You can often remove the drive by locating a screw on the bottom of the notebook about 4-5 inches along the interior and generally near the vertical center of the Optical Drive's dimensions. Once located, remove the screw and use a small flat screwdriver or nimble fingers to remove the drive. If you encounter even moderate resistance, stop attempting to remove it and ensure the proper control screw has been removed to allow you to slide out the drive.
A second option in this scenario is to remove the flat or contoured bezel covering the Optical Drive fascia. After doing so, locate a pin-sized hole (sometimes labeled EE or with an asterisk) along the face and push it in using a small flat or Torx-based screwdriver, a pen tip, or an unbent paper clip. This will emergency eject (EE)the optical drive tray, allowing careful access to the interior and the lost media likely still inside it.
If you are unable to locate the media after following these guidelines, it is likely the media was inserted in the small space between the notebook casing and the Optical Drive's exterior surface. Remove the drive completely and attempt to locate the media. If you cannot, you may be incorrectly assuming or recalling it's initial placement. Double-check your brain's memory. :)
If you are convinced your media is inside the notebook and these solutions fail to assist locating it, the notebook may need much more extended disassembly to resolve this problem.
Nov 21, 2010 | Computers & Internet
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
Unable to remove virus
Try Trojan Remover, http://www.simplysup.com/ Alot of times virus scanners will pick up autorun.ini files on a memory cards and assume them to be a virus. If Trojan Remover doesn't find anything, then its probably nothing. AVG, NOD32, and Avast are known for false alarms
Jun 06, 2009 | Kingston 4GB Secure Digital High Capacity...
I am trying to remove a program from my computer. I click on :set program access& default,then I click on change or remove programs,but i have the error code 5001 and set up DLL.cpp (439)
if you want to remove programm on your PC click on start locate control panel the click on hard and remove programm then locate the programm you want to remove and remove it. by clicking on the programm then follow the instruction. after removing in the control panel go the drive C locate programm file then locate the file of the programm you uninstall.
Mar 05, 2009 | Computers & Internet
Booting from mirrored drive
GO TO STAERT AND CKICK ON IT ... WHERE IT SAYS "RUN" TYPE IN CHKDISK. ALSO CLICK "START" AND CLICK ON "SEARCH" SEL;ECT ALL FILES FOR SEARCH AND TYPE IN CHKDISK .... THIS MAY TAKE A WHILE. IT WILL SHOW EVERY LOCATION OF CHKDISK. CLICK ON EACH ONE AND CLICK OPEN OR RUN. ALSO CHECK ADMINISTRATOR/USER TO MAKE SURE YOU ONLY HAVE ONE. ITS LOCATED UNDER CONTROL PANEL. GOOD LUCK
Aug 31, 2007 | Microsoft Windows 2000 for PC
Kingston Datatraveler Vault Privacy Edition Usb Flash Drive 4 Gb Usb Logo
1,398 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
