LG Over-the-Range Microwave Logo
Steve Chandler Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven does not heat and makes loud, continuous "hum" when turned on and related to turning of oven table.
Our LG Microwave suddenly does not heat and makes a loud, continuous sound when turned on. Sound sounds like it's related to turning of table inside oven and begins as soon as oven is tunred on. Thank-you.
Ginko
Level 3:
  • LG Master 19,396 Answers
  • Posted on Apr 27, 2009
Ginko
LG Master
Level 3:
Answers
19396
Questions
25
Helped
8076694
Points
55462
Est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
How to fix loud hum and no heating in Sharp model R-308KW?
There could be a variety of reasons why this happens, but the likeliest
reason is the secondary interlock or monitor switch is broken. These are micro switches that tell the microwave that the door is closed. If this switch is broken, then the microwave thinks the door is still open and the carousel table won't turn, and the oven will not heat up.
I replaced an interlock switch last Saturday. The switch was $7.00 and took me an hour.
Ask your local repair person to test the interlock and monitor switches first, then go from there.
Good luck,
Hank
1helpful
Heating element does not shut off even when microwave is off
All electronics that have relays have a problem with the relays arcing shut. Hit the back of the relay firmly to release it.
Microwave continues heating even when off
The microwave has a short. You need to replace it, there's no real fix for it. Keep it unplugged and dispose of it. It will eventually catch on fire, and this isn't an exaggeration.
Maytag Microwave over Oven: comes on with lite and table turns; loud continuous noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1helpful
My oven makes a humming noise when it is running - either in heat mode or defrost mode. The noise goes from nothing to loud, then loud, then it quits. The microwave is only 2 months old and it has been...
No! this not normal and should be checked out right away, the problem could be in the high voltage transformer being loaded down by the magnetron, or possibly the turn table motor. The warranty must still be in place and I encourage you to take at vantage of it.
It started making a loud humming sound. The turntable still turns, but doesn't seem to heat anything up.
Basic
heatman101
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Basic Microwave Oven Troubleshooting Tips
heatman101
3helpful
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Microwave makes a loud hum and won't heat. What
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgf
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
