Furuno GP31 GPS Receiver Logo
A
Anonymous Posted on Oct 23, 2013
Gp 31 manual - Furuno GP31 GPS Receiver
OffScotland
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 30, 2014
OffScotland
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2164
Points
Hi How do I reset a futuro gp-31 to factory settings as it is in French and I only speak English. Thank you Chris
This might help .. https://www.manualslib.com/manual/55623/Furuno-Gp-31.html?page=78#manual
2helpful
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
12helpful
2answers
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
18'' radome ?
no way no way no way sorry
1helpful
I've just bought a boat with a furuno gp 31 , no user manual .is there somewhere I can download one thanks.
Hello!
You can download one here:
http://www.furunousa.com/Furuno/Doc/0/5OS1KKAL2OP434ND790LNUEPEB/GP31-GP36%20Operator%27s%20Manual%20%20k.pdf
Copy the entire link into your browser and you should have it.  It is in PDF format, so if you need a PDF reader, go to www.adobe.com and get one for free.
Hope this helps,
Ken
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Top Furuno GPS Experts
k24674
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
