Di183 standard m/c with GDI printer,to Print thru PCL driver u need to have Image controller installed in the m/c. So delete the printer driver & install the GDI printer driver.
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
I already answered this, but the response did not get posted.
The short answer is that the PCL XL interpreter has picked up the use of the "Escape Code" (0x1B) in the incoming datastream. This command is used for the standard versions of PCL, most notable PCL 5e. It is not used in the PCL XL datastream.
I think u have installed the PCL 5 or PCL 6 driver.Not to worry
Go to www.hp.com and download the PS driver for LJ 3055. Install the driver,u will not get the PCL XL error any more.
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
