Seagate 500GB FreeAgent GoFlex Hard Drive Logo
Nicholas Stevenson Posted on Oct 24, 2013
My seagate FreeAgent GoFlex external hard drive makes a weird noise and I cannot access it from My Computer
Fulgurite Fractal
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 24, 2013
Fulgurite Fractal
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
409
Points
10
Bad news.
If a hard drive makes a clicking noise, it's most likely lost forever.
I have been able to rescue files from a dying hard drive which refused to cooperate with Windows (however it didn't make weird noises). I just plugged it into an Ubuntu computer and managed to copy a portion of the files with a command line tool called rsync. About one third of the files were corrupted but the rest of them were ok. The copying took several hours to complete. The drive had a significant pile of bad sectors, so that's why...
Another (rather difficult) rescue tool would have been ddrescue. Using it would probably take an entire day or so. As long as the hard drive communicates with a linux computer in any way, tools like rsync or ddrescue could be used.
However, if a hard drive has reached a point where it makes some extra noises, it's probably way beyond any point of reasonable recovery. Assuming it does not communicate with any computer, be it windows or gnu/linux, fixing your drive could require some extra knowledge, hardware or money.
There are companies who are willing to fix that hard drive for an outrageous sum. Before even considering commercial data rescue options, you need to as yourself: "Is my data really worth that much?" If you are working on an important project and years of work is on that drive and there are no backups anywhere, letting a company take care of it could be your cup of tea after all.
Testimonial: "Thanks so much, but fortunately i got a different USB cable out of my box and it worked. Thanks anyway, Nicholas"
  • John Sims Apr 21, 2014
    I had the same problem with my Seagate drive and it turns out that the drive motor failed. Since I was using it for backup only, I junked it and went to Carbonite. this was the third Seagate drive that had the same problem and all three had the problem a month or two after the warranty expired. Seagate used to be a great product but not any more. I am very happy with the cloud. All in all, the yearly charge for Carbonite is cheaper than having thse drives failed time after time.
5 Related Answers
Anonymous
  • Posted on Feb 03, 2008
SOURCE: Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Anonymous
  • Posted on Jul 24, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Anonymous
  • 916 Answers
  • Posted on Sep 07, 2009
SOURCE: Seagate Freeagent Dropped
Unfortunately what you are describing is a damaged platter inside the hard drive. You may be able to get a technician to recover some data but generally this means the drive is gone forever.
Azrael SRL
  • 11800 Answers
  • Posted on Jun 01, 2011
SOURCE: can you use a Seagate 500GB FreeAgent GoFlex
Yes, but because it's a hard disk and has low transfer speeds it will actually slow down the pc instead of making it work faster. Ready boost is designed to be used only with memory sticks of the latest generation.
Anonymous
  • 28 Answers
  • Posted on Aug 12, 2011
SOURCE: My Seagate Freeagent Goflex 1Tb
Hello Gravi,
Please try one of the following options.
Try different USB ports.
If that didnt work, then try updating/reinstalling your USBdrivers.
Try after these options a reboot first.
Also take a look at this page where some driver problem for your specific harddrive are explained!
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
I hope this helps you out!
With kind regards,
MisterN
Why does my Seagate FreeAgent GoFlex, 1.5 TB, external hard drive USB 2.0 make a clicking sound and will not connect to my Satellite receiver?
Does the drive work with a computer? This is an important test to determine if the drive is bad, or if it is an interface problem. Check the satellite receiver instructions for using external USB devices. Many times, these types of devices do not have interfaces with drivers for external hard drives.
Seagate Freeagent goflex not detecting
It sounds like the drive is failing. So you will need data recovery services.
A remote service is http://FreeDataRecovery.us
1helpful
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
3helpful
Can you use a Seagate 500GB FreeAgent GoFlex external Hard Drive with ready boost in windows 7?
I am looking for a manual for FreeAgent GoFlex Desk USB 3.0. I have no idea how it works. It doesn't need fixing, I need to know how to do various tasks.
Here's a link for all the Seagate FreeAgent GoFlex external hard drives support page: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-support&vgnextoid=884623db95b07210VgnVCM1000001a48090aRCRD
I would suggest finding the quick start guide for your external hard drive and reading that first.
Thanks for using FixYa; please post back if you have any problems and I will help you further.
1helpful
How do I work on my data on the Seagate FreeAgent 2TB GoFlex Desktop USB 2.0 Hard Drive as my computer memory is at capacity. I want to be able to use my external hard drive as an extension of my computer...
Assuming you are using a Windows operating system, you can just plug it into your computer's USB ports, and the computer will recognise it as another hard drive.
Instructions:
Double-click on 'My Computer' and take note of what drive letters are there (C:, D:, etc.) before you plug in the Seagate Freeagent.
Plug in the Seagate Freeagent. You'll see the new drive, likely E: or F: (depending on what is already there before you plugged in the Seagate Freeagent)
Double-click on the new drive, and it'll open up and you'll see the files stored on that drive. You can drag and drop files and save to this drive like any other folder on your computer.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
