f non c'? ancora alcun cambiamento, quindi contattare Epson per ulteriori consigli. Si noti che ? necessario fornire quanto segue:
Il numero di serie del proiettore (situato sul retro dell'unit?)
Il codice di richiesta a 5 cifre visualizzato dal proiettore
Una copia della prova di acquisto del proiettore
https://www.epson.eu/viewcon/corporatesite/products/mainunits/faq/2867/2759
Support & Downloads: Epson EMP-83H / Epson EMP-83
Return back to support options for Epson EMP-83H / Epson EMP-83
Print
My projector is displaying 'The projector's operation will be locked'. What should I do?
Some Epson projector models include a password protection feature as a precaution against theft. In the case of special, educational use only 'e' editions like the EB-X6e, this security measure is enabled by default.
When password protection is enabled, entering the wrong password three times will cause the projector to be locked. A power cut or other power outage can also trigger the projector's security. In either case, the projector will then display:
- "The projector's operation will be locked"
- "Request Code xxxxx" (a 5-digit number)
This article explains what to do if you receive this message, and answers some related questions.
The projector will display the error message for approximately five minutes, then switch to standby mode. When this happens, follow the steps below to reset the projector.
Warning:
Please follow these instructions exactly, and only carry them out when absolutely necessary. Entering a password incorrectly 30 times in succession may cause your projector to become "hard locked". If this happens, your projector can only be unlocked by a specialist engineer.
How to reset the projector
- Power off the projector using the power button on either the projector or the remote control.
- Remove the power cable from the back of the projector.
Caution:
You must physically remove the power cable from the projector. If the projector is ceiling-mounted and connected to the mains by a long extension cable, ensure that the cable is fully unplugged from the wall or ceiling power socket. The projector must be completely disconnected from the mains power supply or it may not reset correctly.
- Leave the projector disconnected from the mains for 15 minutes.
- Reconnect the power cable and power on the projector.
- The projector should display your normal password prompt screen. Enter your password and the projector should resume normal operation.Otherwise, if the projector still displays the same message, repeat the steps above and ensure that the projector is fully disconnected from the mains for 15 minutes. If there is still no change then contact Epson for further advice. Please note that you will need to provide the following:
- The projector's serial number (located on the rear of the unit)
- The 5-digit Request Code displayed by the projector
- A copy of your proof of purchase for the projector
Thank you for that. I will get onto them on Monday and see how far I have to run!
A "Keypad locked" displays everytime a key is pressed on my Optoma DLP projector. The projector does not function. How can I unlock my projector?
unlock epson emp-83e projector
our company epson emp x5 projector is vertical line are while running time, i have clean lens miror also, but problem not rectified.
