My bush alba combi turns itself on whilst on standby but keeps turning the volumne down i can see the volume adjusting itself even when i turn it up it goes bk down help!!!!
SOURCE: Volume
It's rare but happens. Sometimes the volume button (or rather the plastic piece that activates the button when pressed) can get stuck. That or there has been a cleaning chemical leak down onto the button on the board itself and corroded it, causing a constant short.
As for the second Q, I feel that your TV may have received a shock through the audio line and the audio amplifier may have taken the hit. These problem can lead into multiple bad compontnts, such as a bad SMD IC on the bottom of the board.
SOURCE: tv volume turns down by itself
I had that happen to me once and found that one of my remotes was under the sofa cushion, However, I would look at the connections on the pcd that has the volume controls on them, the down switch either has moisture or corrosion behind it, or the switch itself is faulty, if not, remove all dust from inside the set, some may be causing conductivity on the processor, I believe it will be a mechanical type fault rather than electronic...try that...Phil
SOURCE: The volume on my tv goes down all by itself. I
Try taking the batteries out of the remote or taking it out of range from the tv. Then try turning the volume up on the Tv manually. If the volume continues to go down on its own then it is a problem with the tv set itself. If the problem stops with the remote out of the picture then it is a remote problem. As far as powering the unit off may be a similar issue. If there is an on/off button on the tv and it works to turn the power on but not off then it is a tv issue. If the remote turns the tv on but not off it may be something as simple as the wrong code being programmed into the remote(universal remote) or if it is the factory remote it may be an issue with that. You could try getting a new universal remote that works with your unit.
SOURCE: when i turn the tv. on, the volume line appears
My volume is stuck at 100 and won't turn down on the tv itself, please help??! Thank you!
