First, make sure the device
you want to connect with your remote is turned on, whether that's the
television, DVD player, VCR player, etc. Now aim the Innovage remote at
the device. Press the button on the remote control that corresponds to
the device (TV, DVD, etc.). Now, press and hold the SET button on the
remote control until the LED light on
the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on
the remote control (see list below). When you press the fourth digit,
the LED light should turn off. This means the remote and the device are
"speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the
Innovage remote doesn't recognize the code for your device. Verify the
correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at
the device and press and hold the Code Search button in the upper left
of your remote for at least 3 seconds until the LED light on the remote
turns a solid red. Press the button on the remote for the item you want
to program
(TV, DVD, etc.). The LED light should blink
once and then remain a solid red.
Press the On/Off button slowly until the device you want to program
turns off. The LED light will blink once each time you depress the
On/Off button. When the device you want to program turns off, press the
ENTER button. The LED button will turn off and the code for that device
will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular
device. It may take several programming attempts until you find the code
that works
with your device.
