Here are some link to check out
http://www.sewingpartsonline.com/singer-6136-sewing-machine-parts.aspx
http://www.sewingpartsonline.com/zipper-foot-singer-507836.aspx
http://www.sewingpartsonline.com/zipper-presser-foot-low-shank-55411.aspx
http://www.sewingpartsonline.com/snap-on-presser-feet-set-low-shank-11-piece.aspx
also try ebay for parts
SOURCE: what free motion foot can you attach to this singer 3116 model?
This low shank foot will work on that machine. Singer 3116
sewman7
SOURCE: I have a singer 4552
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
