Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
    Prodigy:
    An expert who has answered 500 questions.
  • Frigidaire Expert
  • 650 Answers
I agree with Owen, it sound like an electric smooth top stove. The burner or element is a two piece unit. these usually has a special switch and are not interchangeable with the other switches unfortunately. You will have to do a continuity check on the burner itself to determine if the problem is in the element. Most likely it is the switch but I have seen bad elements in the burner or burned wires on the elements.
If it is gas then the flash jets are probably clogged to the inner burner. A small paper clip works well to clear the holes.
Posted on Mar 22, 2015
    Top Expert:
  • Frigidaire Master
  • 2,907 Answers
Sometimes the burner holes get clogged. I use a toothpick to clean out the holes.
Hope this helps.
Posted on Mar 21, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Posted on Oct 24, 2013
4 Suggested Answers
SOURCE:
Jimster
  • 240 Answers
SOURCE: Frigidaire glass top
You will need a wiring diagram and a multi-tester (volt meter, etc). Find the diagram for the elements, trace your wires to that switch, and check for voltage coming out of that infinite switch. If you have voltage, then its your element (85% chance its the element anyway). Good Luck.
Posted on Nov 05, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
    Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
    Posted on Mar 13, 2013
    Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
    I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
    Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
    Mar 13, 2017 | Whirlpool RF263LXTQ Range
    FRIGIDAIRE GALLERY STOVE MODEL CFES387CFS The two small buttons on the front control panel permitting to change the heating area (small or large sizes) of the two front burners are broken. When we open any...
    This is not hard or difficult to replace. You simply need new switches for this unit. You can contact us at accurate-appliance-service.com from 7 AM until 9 PM CST Monday through Saturday for all you appliance parts needs.
    We hope this helps and we hope to hear from you soon.
    Oct 27, 2009 | Kitchen Ranges
    GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
    Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
    Aug 22, 2009 | GE JBP30 Electric Kitchen Range
    Large burner won't shut off
    This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
    This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
    Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
    If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
    Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    My electric stove top burner only works on high
    This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
    Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
    Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
    211 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Marvin
    Marvin
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
