SOURCE: Frigidaire affinity ATF6700FS won't
Some error code there? This may sound strange but give it a try. Unplug the electric. Leave
unplugged 2 or 3 minutes, then plug it back in. This allows the
controls to reset. It worked alot cases.
Inicially I could think
in some drain problem, check hose for any clogged or obstruction there,
try to jump voltage to the pumo to confirm if this device is working.
If this dont solve it, you will need to check timer; in this link could
finr some tip test: applianceaid.com/direct.html#burnt_timer
Visit this site to identify some parts replacement that you could need: partsearch/model.aspx?model_id=5152465&diagram (sample)
If you are not sure about how do it this job, or your machine is even under warranty, call the technician service.
Hope this helps.
SOURCE: frigidare affinity error code E23
Hello, welcome to FixYa.
I understand you have a Frigidaire Affinity ATF6000 series washer with an error code E23, correct ?
If that is indeed the error code you receive in the display it is potentially bad news unfortunately, as that indicates either loose wire (fingers crossed) or a failed drain pump relay on the control board. This is how it is described in the Frigidaire service tech manual.
Further to this, if it is not a loose wire at the pump or on the control, the only remedy is to replace the control board, unless you are proficient at electronic repairs (including soldering techniques) and can purchase an exact relay and replace just the relay...though that doesn't guarantee the control hasn't suffered collateral damage in the process.
A new control is part #134523106...
it is available at several on-line parts vendors such as "repairclinic.com" or "searspartsdirect.com" to name a couple as these links will provide.
http://www.repairclinic.com/PartDetail/Main-Control-Board/134523106/1191145
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Washer-Parts/134523106/0026/417/Model-ATF6000ES1/1428/0153200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=R0604038&diagramPageId=00001&productTypeId=0153200&searchModelNumber=ATF6000ES1&subCompDesc=Control%20panel&brandDesc=FRIGIDAIRE&modelDesc=WASHER&blt=11
Hope this answers your question and helps you move forward. Let me know how you make out or if anything isn't clear. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
