SOURCE: canon ixus 500 permanently out of focus
Zohail,
I'm sorry but it is not ccd image issue, it calls focus data error and camera requires Flange-Back adjustment by Canon Service Center Tech or Lens Assembly will be replaced.
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
SOURCE: Canon PowerShot A480 won't take photo.
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Testimonial: "I new it must have been a simple solution. Camera has been a little gem. Thanks :)"
Remove the battery, press and hold the power button, or turn the power switch to ON position(depends on the option available in your Camera) for more than 30 Seconds and then reinsert the battery to resolve the issue.
