SOURCE: 2002 explorer tail light for trailer
There is a small black plastic box under the hood that contains several circut breakers. The breaker for trailer towing is located here.
SOURCE: no running lights on boat trailer towed by 2008 ford f150
You can purcahse a tester which will connect into the F-150's wiring harnes. If the led lights up, the problem is witht he trailer's wiring harness. this tester will indicate the proper operation of the brake light and turn signals.
SOURCE: Running lights on trailer won't work
it could be the plug where it connects up under neith try twisting it there while the lights are on maaybe corroded there .then just pull apart and put some electrical contact grease in it and put back together or us a test light and see if there is power there first .
SOURCE: factory trailer connecter for trailer plug in - no current
Also try http://www.etrailer.com/faq-wiring.aspx. They have a great website with lots of info. Check ground.
SOURCE: were is fuse for trailer running lights ford f250 ...
Passenger Compartment Fuse Panel, Fuse # 38.
This is in the Owners Manual on page 209. If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Also handy to search for keyword in the PDF version.
