Caterpillar 1984 3208 Generator Set 75, 100kW Brochure Logo
a
a baby Posted on Oct 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My caterpillar gen electric gen set shown a fault alarm and emergency shut off after its not starting no any signal
sherlywang
Level 3:
Master:
  • Master 428 Answers
  • Posted on Aug 08, 2018
sherlywang
Master
Level 3:
Master:
Answers
428
Questions
0
Helped
198541
Points
1063
Generator set is mainly composed of engine, AC synchronous generator and control box (screen). The engine is part of thegenset that generates power and is the most prone to failure. There are internal and external causes fordiesel generator failure.
For more details, please visit:
https://www.dieselgeneratortech.com/generator-sets/Reasons-and-Solutions-for-Diesel-Generator-Failure.html
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Caterpillar Expert 573 Answers
  • Posted on Nov 23, 2013
Renee F
Caterpillar Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248169
Points
680
What fault alarm did it indicate? No start signal at all normally means a safety lockout, is it cranking at all? Can you give me more details please
2answers
I have kohler 20RESA generator. I cannot clear the fault that says "engine m/n invalid shutdown". Can anyone help with this? I did go through the reset procedure, but fault reappears immediately.
Emergency shutdown operation is required when one of the above conditions occurs in diesel generator set.Diesel generating set itself has an emergency stop button, at this time, press the emergency stop button or quickly press the stop control handle of fuel injection pump to the stop position, the diesel generator will quickly cut off the load, and immediately close the throttle, while the red "emergency stop" light is on. Need to press the button again to delete the emergency stop signal. If there are serious faults or distribution faults, you can also press the button on the control panel, and the unit will stop immediately.
In fact, all faults always give operators some warning signal before spare parts break down or engine damage occurs. So the operators need to be smart, and notice alarm signals (sudden drop in oil pressure, abnormal sound, etc.) and immediately stopping the engine.
Emergency shutdown operation is different from normal shutdown operation.
Emergency shutdown operation.Once the operator finds that there is a serious fault or distribution fault in thediesel generating set, he can press the emergency stop button of the control panel to stop the unit immediately. If there is no special circumstances, we advise users not to stop the unit at will through the emergency stop button.
Perkins 80kva Diesel Generator showing fault "failed to stop". I have a DSE7310 control unit on a Perkins Generator and Leroy Somer alternator.
Hello, did you try to contact your generator supplier to get the solutions? If not, here is some suggestions to you:
Try to find wthat is the cuases of generator stop.
Generally speaking, the design of sound and light alarm is not allowed to eliminate the light alarm artificially. Sound can be artificially eliminated, and light can never be artificially eliminated.
Because the signal of the light alarm comes from the sensor, when the fault disappears, the signal of the sensor will disappear and the alarm light will also be extinguished.
Cummins, Perkins, Volvo, Deutz, Wechai, Yuchai, Shangchai etc. diesel generator set specification:
2answers
What is the p03 code for kipor generator
P01 oil pressure alarm
P02 frequency alarm
P03 voltage alarm
P04 unit overload alarm
P05 start-up fault alarm
P06 emergency shutdown alarm
P07 charging fault alarm
P08 unit overheating alarm PRE-H unit preheating instruction START unit start-up instruction.
Cummins generator and Perkins generator at website: www.dieselgeneratortech.com. power range is 20kw to 3000kw.
2answers
Aux fault on Kohler generator 5ekd says 17.0 fault check engine
More supports or if you consider diesel generator set in furture, please contact [email protected], or visit at: www.dieselgeneratortech.com
On loss of utility power, Koehler residential generator (new) automatically starts up but then shuts down within seconds with ac sens loss fault; only behaves like that on loss of utility power.
I would think it's not wired in right. The Shore power sensor circuit may be tied in to Generator power. Control panel would bypass this shore power sensing circuit.
HOW TO SET ALARM
In the Alarm Mode, use D to scroll through the alarm screens until the one whose time you want to set is displayed.
2. Hold down A for about two seconds until the alarm time starts to flash. This is the setting mode.
3. Press C to move the flashing between the hour and minute settings.
4. While a setting is flashing, use D (+) and B (-) to change it.
  • When setting the alarm time using the 12-hour format, take care to set the time correctly as a.m. (no indicator) or p.m. (P indicator).
5. Press A to exit the setting mode.
To test the alarm
In the Alarm Mode, hold down D to sound the alarm.
To turn an alarm and the Hourly Time Signal on and off
1. In the Alarm Mode, use D to select an alarm or the Hourly Time Signal.
  • When the alarm you want or the Hourly Time Signal is displayed, press A to toggle it between on and off
  • The alarm on indicator (when any alarm is on), snooze alarm indicator (when the snooze alarm is on), and the Hourly Time Signal on indicator (when the Hourly Time Signal is on) are shown on the display in all modes.
To stop the alarm
Press any button.
2answers
Operation manual caterpillar 3412 engine?
I suggest you get one of those manuals from www.reliable-store.com instead
1helpful
Panic alarm does not work. Locksmith verified that it is not the remote fobs.
central timer module" - Dodge Dakota Forum
www.dodgedakota.net/boards/gen/21983.html
Jan 2, 2009 - 21 posts - ‎18 authors
I have a Dak 2000 3.9 Ltr V6, Single Cab, Bare Bones. ... Panic Mode .... ooops....i mean the remote entry and alarm system does NOT work ... i have a 2002 dakata where can i buy a ctm looked all over nobody sell them can thay be rebuilt ... I was out the door $550.00, and they washed the truck also.
Truck wont work/Key Fob won't work/wont start/wont do anything ...
www.ramforumz.com > ... > Electrical
Apr 10, 2010 - 10 posts
Truck wont work/Key Fob won't work/wont start/wont do anything! ... Maintenance & Repair > 3RD Generation Dodge Ram - 2002 to 2008 Dodge Ram Trucks > Electrical... Soon as I manually unlock the door, and open it.... the factory panic alarm starts going off. .... Vehicle: 2004 Dakota Club Cab 4X4.
alarm going off when opening the door.. embarrassing and annoying ...
www.cumminsforum.com > ... > 3rd Gen. Non-Powertrain
Jan 12, 2012 - 11 posts - ‎9 authors
how do I stop my trucks alarm from going off when I open the door? it did it ... to thetruck and opened driver door (it was unlocked) and the alarm started going off. ... I do not have a remote unlocking device (or it doesnt work) so I do all .... alarm will go off then I have to use the FOB panic button to shut it off.
Keyless entry/panic button/alarm - Dakota Durango Forum
www.dakota-durango.com > ... > Gen III Dakotas
We just relocated our cat gen, we start it up but does not generate voltage and goes instantly to cooldown mode.
Which model CAT???? No voltage check the AVR for exciter output first, it may be a control issue shutting down the AVR, so before replacing check for fault sensor input
What can cause a low fuel pressure alarm, and a incorrect actator position alarm on a 3500B gen ste. Tahk you. Clay
Low fuel pressure under load will cause a shutdown but will cause the governor actuator to hunt before it does shut down, check presssure and demand regulator
Top Caterpillar Electrical Supplies Experts
deton8 von Splosion
CJ Rock
CJ Rock
ADMIN Eric
ADMIN Eric
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
