My sanyo 46xr10f has no red led stand-by light and will not switch on ? .
I opened the back up and found a blown fuse i replaced it and i still have the same problem?
If your able to remove the back and see if the main fuse on the power board is blown, if it is replace it and see if it blows it again, if it does you have issues with the hot side of the power board, unless your fairly familiar with electronics you may want to replace the board, they can be found on ebay or shopjimmy...If you don't see a blown fuse your going to need a multi meter to do some tests to figure out what board is bad, as it could be main or power supply making the set dead
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty.
did you check those fuses again after you powered it back up?
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps.
Cheers
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. [email protected] gene
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
