SOURCE: Avaya phone constant ringing nonstop
My best advice is to contact your local vendor or telephone contractor.
SOURCE: Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
SOURCE: Privacy
What you are experiencing is loss of programming. Is this fixed? Could be the batteries need replacing....
SOURCE: trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
SOURCE: I need to set the
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
