Nostalgia Electrics Hard Candy/Sugar Free Cotton Candy Maker Logo
A
Anonymous Posted on Oct 23, 2013
Where can i order extractor head for pcm805 - Nostalgia Electrics Hard Candy/Sugar Free Cotton Candy Maker
How do you remove the headrest on a 2000 Jeep Cherokee
factory service manual 2000. I posted the book free here 300 times.
as they say RTM , read the manual>?
Ill quote the pages for you .
"REMOVAL AND INSTALLATION
HEAD RESTRAINT SLEEVE
REMOVAL
NOTE: When replacing a head restraint sleeve, the
retaining tabs on the sleeve will be damaged during
the removal process. Check the availability of
replacement parts before servicing.
(1) Raise head restraint to the full up position.
(2) Turn head restraint lock thumbwheel to release
head restraint and pull head restraint upward to
remove from seat back.
(3) Insert head restraint sleeve extractor (special
tool 6773) (Fig. 1) and (Fig. 2) into the seat back.
(4) The retaining tabs are positioned on each side
of the sleeve, when inserting the extractor, ensure
that the flat of the collar is facing the side of the
seatback (Fig. 3).
(5) Using a small hammer, tap extractor downward
to release sleeve retaining tab.
(6) Remove extractor tool from sleeve, rotate tool
180 degrees (Fig. 4) and repeat steps 3 and 4.
(7) Remove extractor tool from sleeve and remove
sleeve from seat back."
3answers
My head bolt broke in the cylender block how can u help me to get it out
It all depends on how exactly your bolt was damaged.
1. Bolt head slots were cut off. In this case, you need a bolt and nut extractor. It looks like a nut socket with a special tapered spiral design.
How to use - Put the head of the appropriate size on the bolt and turn it counterclockwise.
2.The bolt head is completely broken off and part of the threaded bolt is stuck in the hole. Then you need a metal drill bit and screw extractor. In the store, you can buy a set, where there are both drills and extractors of different sizes at once.
How to use - The first drill a hole in the bolt. Then insert the extractor into the hole and turn it counterclockwise.
Nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
1helpful
How to remove screws with damaged heads.
Depends on the size. Sears has some specialized tools for this problem. Basically, you drill into the worn screw and then put this extractor from Sears into the hole you drilled.
Since the screws have right hand threads and the extractor has a left hand tread, as the extractor jams into the hole and dead ends, it will spin the damaged screw out of the part.
Jan 15, 2012 • Drills
Lost and need instuctions for cotton candy machine
The Instructions and Recipes for your Nostalgia Hard & Sugar Free Cotton Candy Maker PCM805 can be found here:
http://nostalgiaelectrics.com/manuals/pcm805.pdf
Thank you for using FixYa!
1helpful
Exhaust Manifold giving me trouble
If you have a Drill Machine and access to the snapped bolt, then drill a hole smaller the bolt size in the cetre of the bolt, then insert the Bolt Extractor tool in the centre of bolt, lightly hit it with hammer so it grab the bolt.Now with proper size of spanner tight Extractor Tool in side the snapped bolt by moving the spanner anti clockwise, In this way you can remove the snapped bolt. Note: The ribs or threds of Extractor Tool are opposit to the threads of the normal bolt. So you tight the Extractor Tool, you are unscrewing the snapped bolt.
Frozen, broken kenmore fridge water filter
Hello Leslie176,
They are called reverse twist bolt/screw extractors..
The prettiest I have ever seen came from EASTMAN restoration products..
You are looking for the variable sized set that fits into an ordinary soct wrench with... EXTENSION (should get you into the filter housing...
ELSE
You will hhave to replace the whole Filter housing
IRWIN HANSON Hex Head Multi Spline Screw Extractor Set 25 Piece 53227 Hex...
Check out the eBAY version
(you don't need QUALITY STUFF for plastic
Hanson AHN53204 7 32 034 Hex Head Multi Spline Screw Extractor Bulk NEW...
Top Nostalgia Electrics Kitchen Appliances - Others Experts
john h
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
