SOURCE: How do I reset the drum counter on MFC-9440CN
To reset the drum unit counter, follow the instructions below:
Testimonial: "THANK YOU THANK YOU THANK YOU Quick response and WONDERFUL HELP TO START MY MONDAY:)"
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
SOURCE: dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
SOURCE: Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
Brother Drum Reset Instructions:
This works on the Brother DR-510 and many others.
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
