When I copy AVI film to archos, it plays the movie approx. 1h09min or so, and stops. I have checked the AVI file with XP media player, it is 1h 27min long. Tried different AVI files, the result is the same. Firmware: OS 1.7.20 Thanks. M.
I had the same issue.
The size of the AVI cannot exceed 1gb or the end of the movie will never play.
I had a movie that was 1,7gb. 2 hrs and 15 seconds.
The Archos recognized this as a 1.7gb file and 2:00:15 long.
As soon as the movie started, the time line bar at the bottom of the screen went from 2:00:15 to 1:10:25. Basically, it cut off the last 50 minutes of the movie.
I simply divide the movie into 1gb chunks.
I decrypt the DVD to the computer
Use Nero Recode to convert it to and MP4. Divide the movie into 1gb chunks and Maximize the Volume.
Use SUPER to convert it to an AVI / MPEG-4 / MP3.
Copy this to the Video folder of the Archos.
This is simply something that Archos does not want to admit is an issue. They want you to purchase the Cinema plugin.
I read somewhere about a file size limit - as opposed to a playing time limit, 1G? 2G? I forget. It's a filing system limitation, not unique to Archos. If that's it, you might try converting your AVI to something with a smaller file size, or split the AVI into 2 files (part 1 and part 2)
EXACTLY THE SAME PROBLEM, RUNS FOR 1 HOUR AND 12 MINUTES, THEN GOES TO THE NEXT FILM. NOTHING ON THE ARCHOS FAQs ABOUT THIS PROBLEM EITHER, WILL HAVE TO CALL THEIR TECH SUPPORT AND HOPE THAT THEY CAN HELP.
same with mine dosnt play all to the end
Talked to Archos tech support.
Archos have trouble playing files with file size >1GB.
Suggestion, when converting files to AVI, keep file size around 800MB with less resolution. ( not much an issue)
I have same problem. there has to be a solution that prevents me from having to re-convert all my movies to lesser quality, smaller size format... that would be an unacceptable solution. Most movies now are longer than 2 hrs and more than 1gb in size. HELP ME!
I called archos they gave me some file to download from another site, but it didnt help
Gary
