SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
SOURCE: Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
SOURCE: Samsung LN-T4042h to PS3 "Not Supported Mode"
i fixed it, on the PS3 u hold the power Button while holding then Switch the power button on on the back for like 10 sec and it resets the picture settings to default
SOURCE: I've had this tv for 1.5 years. It has 2 colored
This problems u have is useally causes by the board,that call the T-CON decoders board.This T-CON decoders board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Testimonial: "Thanks guru. Why does problem go away after 1 hour?"
SOURCE: my samsung tv wont connect to my ps3 through the
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
