I have a Samsung zp-z5-z9 and need a instllation cd for windows 7 can you help me thanksI have a Samsung zp-z5-z9 and need a instllation cd for windows 7 can you help me thanks
You can't post conmments that contain an email address.
Go into my computer then right click on the removable storage icon and then on format.
Hope this helps, I have had mine for nearly 2 years and it has only allowed me to play one album for the last 18 months, the worst £130 I have ever spent.
Try to take apart the player and disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player.Alternatively, try eBay for a new battery - there are plenty there.
A search of eBay, a place i look to check availability gives a number available. Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron. Otherwise twisting the wires together is probably good enough. Tape the joins to strengthen and insulate them.
To reformat your MP3 player. You need to connect first your device to your computer then under my computer right click on SAMSUNG device under removeable devices then click on FORMAT.
Hope this helps
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Here is the user manual for your player if you need it;
http://downloadcenter.samsung.com/content/UM/200601/20060124115711375_YPZ5-USA-ENGLISH-0.0.pdf
Page 18 states that you can only sync with wmp 10, there is no alternative software that will do the job.
Hope this helps :)
