LG DLE2532W Electric Dryer Logo
k
kalisha Posted on Oct 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dle1310w amazingelectric I dropped something in the front panel of my lg dryer dle 1310w. I need to remove the front panel. How do I do that?
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Oct 31, 2013
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146115
Points
960
A putty knife will do. you need to release2 clips towards the top. about5 inches from both side
3 Related Answers
Anonymous
  • 1124 Answers
  • Posted on Jul 09, 2009
SOURCE: need to buy a side vent kit for a LG model DLE
Try here
http://www.repairclinic.com/lg-washing-machine-parts?ctt_id=5201150&ctt_adnw=Google&ctt_kw=lg%20washer%20parts&ctt_ch=ps&ctt_entity=kw&gclid=CMv5x4zBx5sCFQJ2xgodeSfFAA
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 15, 2009
SOURCE: I have a DLE 7177WM LG electric dryer is sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 03, 2010
SOURCE: I have a LG Tromm
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
LG dryer dle1310w won't start. There is power but the control panel looks dead.
first take top off(two screws in back and then slide top back about 2" and lift top up and off)
check for wire connections being fully seated to the control panel.
check that the drive belt is there and tight around drum. if broken, it disconnects a power switch to the motor.
also check repairclinic.com or appliancepartspros.com for repair videos
How to change the sensor on the LG DLE1310W
Moisture sensor? Why would you need to replace that? Is it tearing your clothes up?
My LG DLE 5932w CONTROL PANEL WON'T LIGHT UP AND THE DRYER ONLY BLOWS COLD AIR. COULT THIS BE A BAD FUSE?
Check the 220 volt circuit breaker or cycle it. If on the other hand you have fuses instead of breaker panel, with 220 volt you should have two fuses to contend with and one or both may be blown.
Nov 18, 2011 • LG Dryers
Ok, I have an LG Dryer, model # DLE 0442w. It is making a horrible vibrating noise. I believe it has something to do with the venting system. I have tried just about everything to get the front of my dryer...
Use a flat screwdriver and place it in the gap between the front panel and the top panel about 4" from the sides. Push in to unlock the clip holding the top panel to the front panel. There is one on each side. Lift the top up and remove the 2 screws holding the front panel on top. Now open the door and remove the 2 screws holding the front panel to the filter screen insert. Pull the whole panel out and disconnect the wire connection to the door switch. Lift the entire front panel up and out and you will have access to the blower wheel on the bottom left.
Good luck.
2helpful
I need a manual for a DLE1310W Dryer. Can you send me one.?
go to this web sight and down load your manual.
http://www.lg.com/us/appliances/dryers/LG-electric-dryer-DLE1310W.jsp
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 • Dishwashers
2helpful
Good Luck,
I hope this helps
Lg dryer dle1310w, just delivered, machine can't spin
IS THIS A BRAND NEW DRYER? IF SO DELIVERY PERSONEL MAY HAVE NOT REMOVED SHIPPING BOLT/S. GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PART NUMBER 1266806 OR 1266805. OR CALL WHERE YOU BOUGHT THIS AT AND HAVE THEM COME BACK OUT .
Apr 12, 2009 • Dryers
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
