The most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
