SOURCE: Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
SOURCE: showcase freezer fan motor makes constant clicking noise
I have seen this specific problem. and I solved it.
It's the fan "bouncing" against the motor housing. Nothing wrong with fan -- design flaw. The way I solved this problem was to shim the fan mount so the fan was at a slight angle off level -- this keeps the shaft from moving in and out and the fan banging against the housing.
Here's a link discussing your queston about making an air compressor from a refrigerator compressor.
http://www.volksrods.com/id36.htm
SOURCE: Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
SOURCE: Frigidaire Oven making vibration noise when
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
