Question about Kenmore HE2 Plus Front Load Washer
Scrapping sound I think a coin is behind the drum and it makes a scrapping sound when I spin the drum. Hugo
  • 240 Answers
Likely something else like bra wire sticking up from drain hose rubbing basket. remove front kick panel or rear panel and remove large hose from bottom of tub. clip usually positioned in rear. if unit with heater then heater and clip can be felt inside tub. check inside hose
Posted on Apr 26, 2009
SOURCE:
Indsit washingmachine: making scraping noise when spinning. metal drum inside feels loose and is leaning forward making it scrape on whatever is underneath. how do i stop the drum doing this?
If the inner drum is loose the bearing may have failed or the drum shaft spider may have broken. the scrapping will be the drum hitting the heating element.
Dec 30, 2012 | Washing Machines
Scraping sound when you spin the drum by hand. The washer is two years old. front loader affinity model.
does the drum move as you spin it (if so poss stuts) makes a scrapping sound
Just check to see if the drum moves more than it should
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
I get a loud scraping noise when I first start up the dryer
It sounds like the drum is off balance, the drum could be scrapping along the side of the dryer. Check for a loose bolt on the drum assembly. Once it starts running the drum levels out and the scrapping noise goes away
May 14, 2011 | GE DVL223GB Gas Dryer
ED 56 Dryer Scrapping sound like metal on metal when the drum spins
Most dryers are supported by a bearing at the rear and teflon pads at the front. Sounds like one of the pads is worn out leaving the drum to ride on the metal frame. The bearing can also make that sound if it breaking down. Most dryers have enough play that you can lift the drum and turn it. If the noise stops then the pads are bad. You can usually find them at most dryer wholesale or online appliance part stores.
Apr 12, 2011 | Fisher and Paykel Dryers
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My indesit is60v tumble dryer is clunking when it spinning and sounds like it got something stuck in it scrapping inside
More likely to be worn rear bearing, and or drum shaft,or possibly badly worn drum belt
To access the inside of the dryer,remove top cver and right hand side pane llooking from the front.
Jan 28, 2010 | Dryers
Dryer sounds like there is change on the outside
i had the same problem last week on my dryer, turns out that the felt on the drum where its attached to the housing has worn off, my dryer is so old. i did do careful inspection, by sticking my head in the drum and turning it by hand and looking into the seam. it does sound like there was a coin in there, but it was just metal to metal scrapping. im off to my buddys used appliance store to look for a felt seal.plz rate-bozcro
Sep 20, 2009 | Dryers
Dryer Drum Scrapping
You probably need to replace the slides:these wear down and cause the noise you are discribing.900bee5.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Maytag SDE2606 Electric Dryer
Noise when spinning fast
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 15, 2008 | Hotpoint WMA44 Front Load Washer
Hotpoint aquarius vtd00 dryer starts ok then slows down and stops
sounds like your bearings have gone at the back off your drum behind the small middle panel try turning it by hand if it starts scrapping straight away then u need to replace the bearings m8
Feb 08, 2008 | Dryers
Kenmore HE2 Plus Front Load Washer Logo
296 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
