2011 Dodge Nitro Heat Logo
Judi Daubitz Posted on Oct 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hear a short whining noise when I give my car the gas, it seems to make the high pitch whine just till it gets through the first & 2nd gears, it is an automatic then goes away when my speed increases, but starts again after I have stopped & start again.
danoyachtcap
Level 3:
Top Expert:
  • Dodge Master 2,907 Answers
  • Posted on Mar 25, 2015
danoyachtcap
Dodge Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1274832
Points
52081
Check the transmission oil level. That sometimes causes a whining sound.
Hope this helps.
bertman71
Level 2:
Champion:
New Friend:
  • Dodge Expert 229 Answers
  • Posted on Nov 13, 2013
bertman71
Dodge Expert
Level 2:
Champion:
New Friend:
Answers
229
Questions
0
Helped
40775
Points
246
Gears are going out
What would cause whining noise when I push on the gas?
Could be a slipping belt in the motor. Open hood and listen while someone else gives it gas.
Also could be metal on metal grinding. I suggest having a mechanic take a look so you won't burn up your motor.
Here's a link for more info:
Seven ways to pinpoint that high pitched whining noise
1helpful
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
2answers
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
1helpful
2answers
I turn the key and all i hear is a high pitched whining i can hardly hear
Hi Charotte,your engine is not a interference engine.So your in good shape.
3helpful
Rearend prob.[noise]
Here are the common causes or rear end noises
Constant high pitched whine at all speeds: Pinion Bearings or Ring gear carrier bearings
Whine at steady speeds or whines on deceleration: Rear end gear set is worn and will need to be replaced.
Rumbling type of noises are caused by wheel bearings or a tire with a separated cord.
1helpful
My brand new 2009 Highlander has this high pitch whining noise right from the start. It happens when decelerating, like if you go on a little hilly road, once you get to the peak and then just let gas...
Your noise is called over-run and its in the gearbox which is also the diff and thats the noise you are getting .
Its the meshing up of the crown wheel and pinion and the only way out of it is to replace the GEAR BOX ASSY with a S/Hand one as you dont get to many doing that noise.
Let me know how you get on. RON
Sound like a jet engine when you get about 30 mph it continues when you let off gas it seems to disipate as soon as you give it gas it starts again
I am assuming you mean a high pitched whine. a high pitched whine is usually a sign of low fluid. Check your transmission fluid. Then check your differential fluid. the plug in the middle of the diffrential, remove it and stick your finger in there, you should be able to feel oil. If you dont then you need to add some gear oil.
2answers
Whining noise while accelerating in 1st gear
Check the idler and tensioner pullys for your serpentine belt. I suspect the whining noise heard earlier was due to the fact one was getting a bit stiff or rough turning. When you gave it that extra fuel, the sudden load may have finished it off. Sometimes they lock up, and sometimes they fall apart. Check those items first.
2helpful
2answers
High Pitch whine during acceleration
Hi Pullerwife,
I have a few suggestions for you,
First of all, check your air filter, make sure its clean, not clogged, and doesn't need to be changed.
I don't know how handy you are, but if you are fairly handy, check the idler pulley bearings, if your not, have a shop check it out, as a last resort.
Power steering pump/fluid being low is also a possibility, but thats usually more of a lower pitched whine then what you describe.
You say once the vehicle is warmed up, the whining stops. Does Weather seem to be a factor as well?
Hope I've helped, and don't forget to rate.
Lazaruselite
10helpful
5answers
well it could be a few things but most likely you belt is sliping. That is very common and happens to all cars over the years if the belt is not changed. You should check it out. The belt could be bad but it could also be a bad pully. If you dont know what these parts are look them up on google. its very simple
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
