There is an electrical problem.
my suggestion is that you will have to dispose that microwave and get a new one.
you dont want to chance a fire. andwave c yes mircroan cause fires.
A short circuit diode will do that or shorted turns in the magnetron high voltage transformer, or the magnetron or a sticky/contaminated door switch. Hope that helps.
It can be oiled with something akin to Pam (cooking oil spray). You don't want petroleum products in your oven -- it'd take forever to get the fumes out.
I'd try first just spraying some under the turntable as far back toward the center as you can get it -- run oven -- spray some more, etc., etc.
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
