Can't find the Power supply? what kind of cord would i need?
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
SOURCE: Mag Innovision LT982s 19 in
yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
SOURCE: monitor not working with desktop
The pc does not power the monitor. It has to be independently plugged into an electrical outlet.
SOURCE: Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Testimonial: "I posted this question back on 08-27-09 Finally got the right solution. I had never seen a Plug-in for the power-adapter on the Vga-plug itself. Thank"
SOURCE: MAG Innovision LT1919WDb flat screen goes black
When a monitor works for a few seconds or more and goes black it is a problem with the power inverter board over heating because of a bad capacitor or capacitors that are not the right size. There is no problem with the VGA controller since it shows video for a few seconds. I have fixed a lot of Mag LCD monitors with changing just two small capacitors for $0.50 a piece and some of my time to solder them in. Less time as i have gotten better. You can buy the capacitors on Mouser Electronics Online. Just make sure they are the right size and dimensions. I have one of these monitors on my table now and have not determined the exact capacitor that is the issue. I have change five out and it is still doing the same. Four more to go. None of the capacitors looked bad, thus the prcess takes longer. Good Luck
