Remote Starter with Keyless Entry Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO PROGRAM REMOTE
PROGRAM FOUR BUTTON (START,LOCK/UNLOCK,TRUNK & STOP) BULLDOG SECURITY REMOTE
Anonymous
Level 2:
  • Expert 344 Answers
  • Posted on Jan 25, 2010
Anonymous
Expert
Level 2:
Answers
344
Questions
0
Helped
193239
Points
535
Unplug the main harness from the unit for 2 min, then plug it back in and press any button on the remote, the parking lights should flash when a new remote is programmed
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
2helpful
Need to know how to program keyless remote on 98 cavalier
1997 Cavalier remote keyless entry programming.
All Remote Keyless Entry Modules may be programmed to receive four different
transmitters which all may be used to operate the remote control lock system on the
vehicle.
Also, severalvehicles, each with the same system may all be programmed to operate from the same transmitter or four different transmitters.
Step 1. Turn ignition off
Step 2. Ground the program pin.(within one second, Lock, Unlock and Trunk will cycle to indicate module ready for programming.)
**the program pin is the two wire connector plugged into the RKE reciever in the trunk of the vehicle at the Left Wheelhouse. Leave the main harness plugged in but unhook the two wire connector and ground the pins.**
Step 3. Press and hold the LOCK and UNLOCK buttons until:
Lock, Unlock, Trunk, and Horn cycles to indicate the transmitter has successfully been programmed. (This takes no more then 12 seconds)
Step 4. Repeat step 3 for the remaining number of transmitters
Step 5. Remove the ground from the program pin.
Step 6. Verify proper operation of the transmitters.
Keep in mind that 97-99 can be programmed by the owner, 00+ require DEALER programming with the scantool.
I hope helps with this (remember rated this help) Good luck.
1helpful
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
I have two remotes and only one will work
I don't know if you have the owners manual if not you can go to the website and find the programming instructions there.
Just put in bulldog remote start
have to hit unlock to stop it... and learn tach..
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
