Televison & Video Logo
Posted on Apr 26, 2009
LOUD BUZZING NOISE WHEN WATCHING TV, WHEN I MUTE TV IT STOPS
I HAVE A 32 INCH LCD TV THE NAME BRAND IS ULTRA. ITS MAKING A BUZZING NOISE WHEN TV IS ON. I THOUGHT IT WAS MY CABLE SO I TURN OFF CABLE AND STILL BUZZING SO I MUTE IT AND BUZZING STOPS WHEN I UNMUTE IT IT CONTINUES. ITS ANNOYING TO WATCH TV WITH THE BUZZING NOISE ALONG WITH THE SHOW
  • lisa
    lisa Mar 21, 2014
    I had the same problem. I turned up the backlight up and the noise went away. I turned the backlight down and it came back.
lisa
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2014
lisa
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1635
Points
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
2860
Points
22
Try replacing av cords..if not replace tv
Lg lcd tv buzzing sound
You have problems on the sound portion of your board. It could be a bad solder joint causing it to arc to another component or to ground. It could also be just a plain ole bad Amplifier or something. When you mute it you turn all the voltage off to your AF Amps and naurally the noise will stop. Find the sound board and check it for cold solder joints.
Gillight
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
2answers
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
2answers
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
5helpful
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Loud sound from tv
It could be the inverter board going bad. The inverter board is what makes the back lights come on and has transformers on it that have high voltage. any time you have a noise like a buzzing or arcing you should have it checked
2answers
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
