I have the same problem that another has. I reveiced a jabra bt250v, I put into the charger one flash of the light when plugged into the electrical outlet when attempting to charge. No light during charging so headset is not charged thus cionnioty use the headset. Need hepl with a solution with this problemm Thabnk you.
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
I have the same problem! I bought 3 new Jabra BT205! All of them cannot charge!! Please help!
I have the exact same problem and I would appreciate a solution to this asap. Thank you.
slider
Yes I have the same problem - you get a flicker of blue instead of staying blue then switching off when charged. I left it in charger for some time but would not switch on.
Would appreciate a fix
I get a flicker of blue instead of staying blue then switching off when charged. I left it in charger for some time but would not switch on.
mine gets a single flash and then doesn't charge. could really do with some help!
Still no soloution to this problem? WTF!!
I have the same problem with my Jabra 250, please help !!!
