Just a few weeks ago I noticed the right side of the screen, approximately 2 inches of the screen has a dark tint that fades into black. Any ideas?
Ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
only capacitors are defective no others!
ok do you have an ohm meter? or multi tester?
ok! get out the capacitor in the board, the capacitor is have two pins at the side of them have a symbol stripe or arrow that symbol is the negative pin the one is positive! check it to tester with range of X10 or X1K the red prod is to positive pin of capacitor the black prod is to negative prod, if the meter is arch then fast back to zero that is good! then reverse the prod positive to negative negative to positive then the meter is now arch! then suddenly back to zero! odserve the arch of meter.
I'm comfortable taking the TV apart and I can solder but I've never worked on a TV before. Is this something I should attempt? I have a volt-ohm meter but not too sure how I check the capacitors. Any advice?
Thanks for your help!
yes I do
ok, i'm able to get the tv apart but no idea how to find the horizontal capacitors. i'll look around on the web for schematic, or maybe you have a suggestion?
