Hi Maureen, The first thing i would have checked is the battery strap if there is one to make sure it is properly fitted over the battery. Other than that as long as the batteries were from a reputable jeweler, it seem as if you watch may need a movement cleaning and or repair it could possibly be the coil. Most of our watch cleanings run around $80.00 but we do all repairs by estimate. Thank you! Lisa
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second
hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown
all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands
will stop.
Step 2. Turn the crown to
move hands FORWARD (clockwise) until you see the date (for date only) or both
day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue
to move hands forward until the minute hand is approxim a t e ly 5 minutes
beyond the desired minute marker ;then ,gently turn b a ck to the same marke r.
For P. M .time , follow the same procedure ,but first a dvance the hands past 12 o’clock .
N O T E : The date will
advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been
established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The
refore ,on the fi rst day of any month
fo l l owing a month with fewer than 31 day s , the date must be advanced
manually (see Step 5).
Step 4. When the time
standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches
the 60th second, push the crown all the way to the “ I N ”position . All hands
will start instantly.
Step 5. Pull the crown to
the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will
continue to tell time. S l ow ly turn crown one way until the correct date a p
p e a rs .Then for day/date models, s l ow ly turn crown the other way until
the correct day appears .
N O T E : The day is printed
in two successive positions on the day indicator: i n English and in Spanish on
U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is
possible to make use of either position. The display will automatically re m a
i n in the language ch o s e n .
The
date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M
.a s this might affect the calendar mechanism and the accuracy of the date. (
Theme chanism will not be damaged if the crown is turned accidentally during
this
time
peri o d ,howeve r. )
Hope it helped U!
SOURCE: Bulova has mechanical day/date display near 3
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
SOURCE: I can't seem to remove
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
SOURCE: I just had my battery replaced in my Bulova
You can get instructions from their web site by going to http://www.bulova.com/service/servicecenter.aspx and finding your watch in the list.
SOURCE: Bulova Millennia Motion Quartz Watches (kinetic
It seems as though it needs some attention, i.e. serving might be needed.
If servicing proves to be unsuccessful in improving performance, then it should be sent to their service center (see Boluva.com).
