In order to pair a BlackBerry device with a Bluetooth device, the
Bluetooth device must be in pairing mode. Most Bluetooth devices are not
set to pairing mode by default. Therefore, refer to your Bluetooth
device manual for instructions on how to set the device to pairing mode.
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
