I tried to login and a couple pf seconds later i get a box that says "Connection Error: Please ensure device time is correct." Can somebody help me please! thank you
if your yahoo messenger is unable to connect, it all depends on firewall
that blocks messenger connectivity. Try this open yahoo messenger> click on messenger> click on connection preferences> select no proxies>
click OK. Now try login in. Cheers,please comment on this post by telling how helpful it is
Install older version of yahoo messenger.. And let me tell your one thing that, when to try to login to your yahoo account on yahoo messenger, your internet connection must be responding. This you can ensure by keeping your server busy(opening websites). The problem you are telling might be caused when you are trying to login to yahoo account through yahoo messenger and yahoo mail. I recommend you that you open yahoo account through yahoo mail(only if you are unable to sign in to yahoo account through yahoo messenger.) yahoo mail now-a-days is providing yahoo chat service when you sign in your yahoo account on yahoo mail. at left side of your mail box you can see yahoo mini messenger.
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this
is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection Prefrences and use a http proxy.
[Solution # 1]
(1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Here's how I solve it:
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
