Light works, fan does not
Is it a multi speed fan and it doesn`t work on any speed?? Does the fan spin easily?? If not, the bearings have failed. If you can spin it easily, you`ll probably find that the ground wire in the coil has burned away in the connector or within the field coil windings themnselves. If it was just one of the coils, you would be missing one speed only but if it doesn`t work at all, it sounds like the grounding coil that`s failed. Ian
