Black ink will not print. If I change the colour to anything but black, it will print. How do I get the black ink to print again. It is a new ink cartridge.
If soaking a head in alcohol. It will free the ink but then dry just a fast and re-clog.
Try ammonia nad water.
First you need to ensure that this is not a driver problem, by
reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If
the problem is not a software problem, and the printer is recognised by
computer, and the printout is coming as a blank or faded page, then you
usually have a faulty or clogged printhead.
Try first performing
print head cleaning procedure from printer tools, that may not fix the
problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part:
Canon MULTI-PASS F-80 Print Head
$61.00
SOURCE: New black ink cartridge won't print.
Clean the contacts with rubbing alchol. The contacts in the printer as well as on the cartridge. If that doesn't fix it contact the cartridge manufacturer and they should replace it.
