Vehicle Parts & Accessories Logo
g
geoff Posted on Oct 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change heater core in 90 caprice classic - Vehicle Parts & Accessories
Arnie Burke
Level 3:
  • Master 7,339 Answers
  • Posted on Oct 22, 2013
Arnie Burke
Master
Level 3:
Answers
7339
Questions
0
Helped
1821363
Points
21459
Go to library auto section to view mechanics manuals on ur model--wen u take out core-replace blower motor and ac evap at the same time
Dana Newcombe
Level 3:
President:
  • Master 1,564 Answers
Dana Newcombe
Master
Level 3:
President:
Answers
1564
Questions
Helped
540111
Points
4667
Not a party at all. If the car has A/C you'd better call in a favor from your friend the mechanic or you'll rip your hair out. If it doesn't have A/C drain the radiator, remove the two heater hoses by slicing ONE INCH back on each, NO MORE than this. Remove the 5 or six 7/16 retaning bolts from the housing on the firewall.In side the car remove the glovebox and hinge. Remove the support bracket that supports the lower cowl housing. Remove the wire harness connectors from the heater box and place a towel on the carpet. You will, wether you like it or not, spill antifreeze inside while rolling the heaterbox out from under the dash. Remove the core from the box and replace. Easy huh? LOL.
  • geoff
    geoff Oct 22, 2013
    I don't see how u get the dash out. If I could figure the dash out I would be able to change the heater core
95 Chevy Caprice Classic My heat in my car don't work the blower motor works just fine
Use a garden hose and flush your cooling system (specifically the heater core) to clear out any blockage or buildup. Once the water comes out clear put the hoses back on and refill the radiator and overflow tank with 50/50 Antifreeze and see if you have heat. If not the next thing to check/replace is the heater core itself.
1994 Caprice LS. Little to NO heat.
It will be the heater core. If you can smell it inside the car and it's steaming up the windows the core will need to be replaced. Remove the heater core housing and check to make sure its leaking from the core itself. You might get lucky and have a leak from the hoses running to core instead. Hope that helped.
4helpful
Getting water in front passenger floor boaed, what might cause it?
Clogged or disconnected drain hose from the heater core box. Or bad/leaking heater core. Does the liquid smell like coolant. If so bad heater core. If not and the water only when you use the AC then it is a drain hose issue. If neither of those pan out you could have a leaky windshield. However 99% of the time a wet passenger floor is caused by a bad heater core or drain hose.
My heater will only blow hot air once in a while. it has full anti-freeze the core is not clogged?
Low coolant level will cause this situation,and clogged heater core,but it is most likely the low coolant level.
1helpful
My blower works for air/heat but only blow luke warm air. My freon is charged. Any ideas?
Look for a heater control valve under the hood connected to one of the heater hoses and make sure the valve is operating properly. This is what allows the hot water to pass through your heater core. Also your heater core may have a blockage.
5helpful
4answers
1994 chevy caprice no heat. changed termostat. antifreeze full. fans in back of radiator are not moving
Heater core is plugged or you have a air pocket. If you take off the heater lines and try blowing through them both ways. The fans will not move until the engine gets hot.
1helpful
1995 caprice classic, No warm heat
Have you checked the heater core hoses? If they are not "hot" the heater core needs to be replaced
2answers
1994 CAPRICE CLASSIC LS
had same problem need to flush out the heater core .. plus make sure you do not have a air pocket in the coolant system after you changed the T-stat
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
