SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
SOURCE: how do i connect my samsung jet to the internet
The basic is:
1. On your home screen, click on the bottom right "menu" button.
2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings"
3. Click on "application settings"
4. Click on "Browser profiles"
5. At the bottom right you should see: "Search for wi-fi". Click on it.
6. It will now serch for your home wi-fi network.
7. Once it find your network, click on it and enter your security detail.
8. Now you network is listed as part of the Browser profiles.
9. Now you can select your wi-fe network as your default browser profile.
Now when you open the browser it will try to conect to your wifi to start browsing.
Enjoy :)
Ed
SOURCE: before i used to be able to connect to the
check your internet option and make sureto delete cookies...save your provider,s gprs agin .switch off and restart your phone to use this service
SOURCE: I had recently purchased Samsung
Dear Meghna
you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client
this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup
thankyou and take care
Gagan Gupta
Hope this helps. Please rate my response.
Thanks.
Have a good day
i can't download a bbm in my huawei y300 in my phone
how to operate
huawei y300
