Garden Logo
Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
  • 2 more comments
  • cgrenier66 May 04, 2009
    When releasing the bar to disengage selfpropullsion and pull the mower backwards the drive stays engaged and locks the rear wheels.Honda HRX mower
  • Anonymous Mar 17, 2014
    Honda hrt216sda Harmony II axil is loose, allowing the wheel to slide out far enough that the wheel adjuster will not stay in place, allowing the mower to fall to it's lowest position
  • Anonymous Mar 23, 2014
    back wheels lock up when trying to move it backwards
  • Anonymous Mar 28, 2014
    Need 1 set each front and rear wheels I do not know which ones are correct. Mine is hydrostatic and HXE engine MZCB -62xxxxx
Anonymous
Level 2:
Sniper:
  • Expert 109 Answers
  • Posted on Apr 26, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
109
Questions
0
Helped
122270
Points
354
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
1helpful
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
2answers
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 • Garden
1helpful
I bought a self propelled Toro mower and it is hard to pull backwards. I removed the plastic toe guard and that did not help. I also have a White "brand" self propelled and it is easy to pull backwards.
The self propel system uses a type of racheting pinion drive that sometimes gets greased up and wont release like it should.
You would need to remove the wheels and pinions and look at the shaft ends for a key, a ball and a spring. This is the "pawl" that locks the wheels going forward and rachets when the wheels go backwards.
Clean up the parts of all the aluminum colored grease and reoil with something lighter. 3 in 1 would do nicely. Reassemble.
Now the next time you start going backwards and it jams...just push the mower forwards slightly without engaging the drive and see if the unit doesnt free itself.
Good luck and be careful!
Jul 19, 2010 • Toro Garden
2helpful
Self propelled stops working well mowing, I
turn it off,let the drive handle go,pull mower backwards.does it lock the back wheels?if you push it forward,can you hear a clicking noise from the wheels?you should do.lift mower,spin back wheel,should either lock,or click,depending which way you spin it.they have spring loaded pawls that drive the wheel.usually easy to fix.usually dirt,or too much grease.take wheels off,have a look
3helpful
2answers
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
1helpful
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
Top Garden Experts
Jay Finke
Jay Finke
john h
