Hi Rich.
You might like to follow my Oil Burner servicing videos if you think the burner needs servicing.
I also sell a tool for removing the Barrel or Hot Plate
AGA Hotplate Hot Plate Barrel lifter Crane
If an oil Aga is not getting hot, there is probably a restriction in the base. Oil Agas should therefore be cleaned out by a service engineer every six months, although will occasionally require an extra clean. If if turns out that this is not the problem it is possible that there is a fault with the thermostat, although it is usually a restriction that causes the problem.
