Sylvania LC420SS8 LCD TV Logo
Carl Taunton Posted on Oct 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TV does not power on and the standby led is not on. The power cord is plugged in.
Level 3:
Top Expert:
  • Sylvania Master 76,851 Answers
  • Posted on Oct 21, 2013
Sylvania Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007086
Points
237762
Check and replace its main power supply regulator board as card basis.
My element tv elcwf329 wont come on
Connect the power cord to the power socket after you have completed all the physical connections. At this stage, the TV will enter Standby Mode and LED indicator is white. In Standby Mode, press the button on the main unit or on the remote control to turn the TV on.
https://elementelectronics.com/wp-content/uploads/2019/07/Smart-TV-User-Manual.pdf
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Dear Guru, im Peter thanks 4 ur quick response however my problem still remains with LED samsung 40''...i have no display just standby red light it connected with cable (satellite televion) and remote...
Hello Peter, my suggestion is unplug your cable satelite (STB) conection.
Turn on the TV and see if there are changes or is still standby.
If your TV like normal after unplug satelite tv (STB) connection, you should check you STB.
If still not working, try to unplug AC cord from power line. Wait until led display indicator off, that plug again. If it still not working, i think you should call samsung technician to check you tv.
thanks.
2helpful
My television will not turn on. I made attempts to switch outlets and turn on the television manually with no success. I can tell the television is not taking any juice because the standby light is no...
No power to the tv at all?No,LED power light indication or no LED power standy light.The tv power supply board is dead.That the board,where it take in the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
When watching tv froze made very loud noise and would not turn off or any buttons on tv work. unplugged from wall and tv now just illuminates a white led light for the power instead of blue for on and...
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
6helpful
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
