Question about Kingston Computers & Internet
I purchased a Kingston DataTraveller 64gb hyper x 3.0. It works find on my notebook with windows 7 - fine on another notebook with Win xp - but when I plug it into my desktop system it flashes once - shows up property in explorer for a few seconds then dies. I've tried re-installing the usb drivers for my hard drive. All other USB devices work fine - datatraveller 100 G3 64 gb no problem - its just this one stick that's giving me a problem. Any ideas?
  • 128 Answers
Try going to this link might be something very simple but they have good information. http://www.kingston.com/en/support/technical/products?model=DTHX30 could be a case of being a usb configuration problem
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE:
SOURCE: Kingston Data Traveler 2.0 64 GB USB - file system
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
Posted on Feb 09, 2010
amstyl
  • 62 Answers
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Posted on Apr 06, 2011
krbshg
  • 430 Answers
SOURCE: Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Posted on Aug 15, 2012
Kingston microsd using usb adapter is not recognized on laptop (vista premium 32bit) and on hp desktop (win 7)
Have you checked the drivers for the usb adapter. plug it in and go to my devises and up date driver see if that fixed it. vista software may have a problem as they are not updating there software files. but win7 is fine has same filing as xp.
Oct 01, 2013 | Televison & Video
Panasonic cf-74 toughbook cannot load win xp proff. i can load win 7 from usb drive, i can load win vista from cd disk. hdd shows up in bios, when trying to load win xp loads fine until says starting...
It sounds to me like you requre Win'XP Service Pack 3.
If you are using Service Pack 2 or earlier, there is no
SATA support which is why the HDD is not recognized.
Get Service Pack 3 and your problems will be solved.
Good Luck
Aug 08, 2013 | Panasonic Toughbook CF-27 Notebook
How can you wipe a kingston 64gb data traveler
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
Oct 14, 2012 | Kingston 64GB DataTraveler 200 USB 2.0...
Google Chrome with AVG 2012
as win xp is no longer supported by microsoft it is very possible that the updates are not being recognized by win xp and you now have confloicts in the os.
if it works fine in win 7 , then it is time to remove win xp and upgrade to win 7
May 13, 2017 | Google Chrome
I have a kingston datatraveller 200 64GB. I cannot access it and I get the message 2233 Pram. HOW can I read my files?
You can not. This is a damaged Flash Drive. The portion of the chip that holds the programming has become damaged. I had the exact issue. It had to be sent to a level 3 recovery company. Like ADR or Ontrack. I used ADR. Then you can send the device to Kingston for a free replacement but Kingston will NOT do a data recovery for you.
Jun 17, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Unable to format 64 gb kingston pen drive
I am having 64 gb kingston pen drive.
But after formatting from command promt its file system is RAW an i cannot use the drive now.
Beacuse it is showing properties as 0 bytes.
The drive cannot be formatted.
Nov 20, 2008 | Computers & Internet
W98SE Driver for Kingston 1.0Gb DataTraveller Flash Drive
The people at your local computer shop are wrong but, Windows 98 should at least recognize the USB thumb-drive and ask for drivers.
I would remove all the USB Controllers from within Device Manager and restart; allow Windows upon restart to reload the USB Controllers; then plug in the drive and see if Windows at least recognizes and then install drivers.
It seems only the DTI/XX, KUSBDTE/XX, and DTII/XX support Windows 98.
Dec 04, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
82 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
