Freezers Logo
Jillian Posted on Oct 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also down into the freezer section. I have to continually mop the base of the fridge. Water gathers in the drain at the back as if it is blocked. Where should this water be going. Thank you Jillian
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Oct 20, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466235
Points
5959
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
1 Related Answer
Anonymous
  • 770 Answers
  • Posted on Feb 12, 2008
SOURCE: Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
I have a GE fridge and freezer. This is a standard home model, bought at one of those bargain stores about 3 years ago. They are no longer in business. It has been working real good until recently. It...
Hello Tim.
Thanks so much for choosing me for my help with your freezer. I believe you are having one of the most common problems with your freezer as most people have.
No one sit around when they have some spare time and says >> Honey, instead of going to the beach this weekend, lets go pull put out the fridge and freezer and clean it.
Sense you bought it about 3 years ago, and it is slowly getting warmer and warmer and you can hear motor working hard, I would bet it needs to be cleaned. I also would bet, that you have not sense new have pulled it out and took back lower cover off and cleaned it.
Assuming I am correct, this is what you do. First unplug the unit. Store food in a another fridge if you can or maybe a neighbors house until you fix this problem. Now, sense it is 55 degrees now, most likely most the food could be spoiled anyway. So your call on the risk of saving that.
Anyway, you unplug fridge/freezer, as the motor is cooling down, you now pull out fridge and take off lower panel on the rear. Sometimes has tabs, screws , hooks etc.... After you get the rear cover off, then you will notice all kinds of junk in there, fir balls, and just down right dirt. Get yourself a shop vac and start vacuuming all the coil area, and anywhere you can get that dirt and build up out. Even if you have a air compressor hose that will reach to blow it out, or a can of compressed air you can get from any computer section and local store. Anyway, you want to clean it, excuse the expression to the point of you can eat off it. Once you are convinced it is clean, then plug it back in, and fire that baby up, and you will most likely notice quieter motor and cooling down back to normal. Please let me know , Of course you will know instantly when you pull cover off back and if you see dirty and caked up, there is your problem for sure. Thanks Again, Mike
Some kind words with a rating of my help would be appreciated if your satisfied.......
Nov 02, 2011 • Freezers
3helpful
We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
2helpful
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 • Freezers
2helpful
My fridge freezer defrosted itself completely ruining all contents, this was a week ago and it still wont work. I bought it from argos three years ago it's a Fridgemaster
If there is no noise coming from it its poss thermostat or sensor and if compressor is stone cold. If compressor is very hot its sound like a gas or compressor problem.
Sep 29, 2009 • Freezers
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
1helpful
2answers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 • Freezers
5helpful
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Frost freeze-up
Yes to both questions.
You do remove the rubber strips to remove the back cover and yes you can run a wire down the drain from the heater. There actually was a repair kit a few years ago for a different brand of freezer that was exactly that, a piece of aluminium strap that hooked to the heater and stuck into the drain.
Make sure the drain is clean also.
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
