If the number lights are out and the CD player is also dead it sounds like you lost power to the player. Check all your fuses as the radio and CD player may have separate fuses. Also check any visible wires to see if there is a possible disconnect.
SOURCE: CD player error
Try and remove the radio fuse for 30 seconds to cycle power to the unit and then try to remove them. Some of these units have a software issue and a reset can clear it.
SOURCE: Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
SOURCE: 6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
SOURCE: monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
