Where is the oil filter on my yamaha V-star 1100 classic? The year is 2006 motorcycle
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
Its a pain in the *** if you have floor boards on the right side of the bike if your sitting on it. right behind the floor board or peg is a chrome cover held on with a couple of 8 or 10mm bolts remove the cover its a internal filter. if you have floor boards you will have to remove it.
It's just a little low. Can I add gear oil to the resevoir?
